I suspect
@cruiseroutfit can take care of you on the tie rod ends if they ship internationally.
For sorted I would be thinking about all the major service items that these trucks would of required plus items that are worn out with just age. IE weatherstripping and seals. Below is the work that has been done or about to be done on ours in the last six months. To be clear the truck ran fine and rode reasonably well, but this is the work that it has been done to keep it in the daily driver category. To be fair most of this peace is find stuff, but I prefer working on trucks in the garage and not on the side of the road. The suspension work and anti-rattle stuff is for quality of life, but it is really nice being able to have a conversation with others in the truck.
Now will I drive this truck currently across state lines? No. I need to get a couple gauges installed first to make sure I have good understanding of the health of the engine. After that and maybe some new tires then yes. With that said I am also building out the spares that live in the truck and will also live at the house, so if I run into a snag it no big deal. Now is the below a bit extreme in some peoples mind yes and in others no. For me if I own a truck it is expected that truck can go cross country at a moments notice minus topping off the fuel tank.
Brake Rotors x4
Brake Caliper x 4
Brake Soft Lines x 8
Brake Pads x4
Brake Fluid Flush
Every coolant hose.
Every coolant hose clamp
Coolant flush
Heater Valve
Thermostat
Thermostat gasket
Radiator Cap
Timing Belt
Water Pump
Time Belt Tensioner
Oil seals near that work.
Rebuilt Alternator
New Glow plugs x4
New fuel filter
Valve Cover Gasket
Rear main seal
Turbo to cross over hose.
Any hose clamp or bolt I took off was replaced with new if possible.
New Shocks
New coils
New bushings control arms
New sway bar bushings
New panhard bushing
New LED interior lights
Cupholders
New Sun visors
New grab handle
Fix Sunroof
New rear door hinges
New rubber stoppers
New anti-rattle pads
Future Semi-Planned Work
Rebuilt Starter
New engine isolators
New transmission isolator
Convert to manual hubs
New injectors
Rebuilt IP pump
Valve job
Flush and replace remaining fluids
Rebuild steering box
Tie-rod ends
Replace all soft fuel lines
Replace all soft vacuum lines
Upgrade or move back driver and and passenger seats.
Upgrade stereo
Full weatherstripping overhaul
Rebuilt power steering pump
Replace mud flaps
Add heated seats with Toyota switches
