ARCHIVE looking for images tech and any help regarding a original example of 44411-60030 1/79 - 9/83 FJ40 USA-Spec High Pressure Power Steering Line Hose
  • Thread starter Thread starter ToyotaMatt
  • Start date Start date
ToyotaMatt
looking for images tech and any help regarding a original example of :
44411-60030
1/79 - 9/83
FJ40 USA-Spec High Pressure Power Steering Line Hose ?
thanks
matt
here it is i believe ?
but its shrouded in it's cocoon like flame proof armor wrap ?
kinda hard to make out and solid shape , form or hard line portion at both ends
i bet @Landpimp may have some value to add here ......:)
is that a MINI truck upgrade conversion power box
or
a FJ40 part number specific one ?
sorry to ask , but it is more common to see that format ?
your hard return line fitting call out # 44416 looks to be absoluty exact to my parts diagram !
where as my example pics above show the smaller early return line hard fitting buy a simple bent lazy L shape ?
what is your production year and month if you dont mind me asking and do u know if your hard return line #44416 is the early small 14mm HEX
or the later larger 17mm HEX ?
thanks very very much for your tech images and your input too :)
kindly
matt
or
kindly
matt
VIN & Frame 305827. Making it a May 1979 production I believe.
When I acquired the truck I added the missing the ps reservoir, but the hard line and sleeve were there as well as the original brackets for ps reservoir and ps box.
Got a new belt routed and ps was back! As far as I know 40 box is original.
Both inlet/outlet on hard line are 17mm hex
Both inlet/outlet on hard line are 17mm hexView attachment 2954860
are you familiar with term Pedistal or tower here ?
its the large CAST IRON funky shaped bracket the oem steering box bolts to
is your still factory RIVITS in place
or
a different type of bracket maybe
here is a example of what i refer to
thanks
red ink is the Factory fj40 riveted pedestal or box tower
yellow ink is the oem rivets and the return like exactly like u have
below that is a examples of a mini truck adapter aftermarket plate set up
