Hi there - I'm looking at a 2013 LX with about 145k miles and pulled the Lexus maintenance records. Everything was done at the Lexus dealership and all the scheduled maintenance was done.
But part of the records have the entries below, and I'd like to get ya'lls feedback/input at to whether there are any red flags here. It seems the valley plate leak was addressed, but there are also several mentions of serious rust. I have not yet seen this vehicle in person. I edited out some of the standard stuff like tire rotations and checking fluids etc. Sometimes the nature of the text in these records is hard to follow but I think I can get the gist.
SERVICE: SERVICE - 135,000 MILES DESCRIPTION: ~|~SERVICE - 135,000 MILES ~|~ ~|~137909 PERFORMED 135K SERVICE
SERVICE: LUBRICATED INSIDE STEERING BOOT AGAIN AND OUTSIDE BOOT FOR THE FIRST TIME. DESCRIPTION: ~|~STEERING SHAFT BOOT WAS LUBRICATED LAST VISIT. STEERING WHEEL STILL SQUEAKING. ADVISE. ~|~ ~|~137909 LUBRICATED STEERING SHAFT BOOT INSIDE AND OUT SIDE BOOTS AND NOISE IS GONE
SERVICE: PADS AND ROTORS FRONT - REPLACE DESCRIPTION: ~|~PADS AND ROTORS FRONT - REPLACE ~|~ ~|~137909 REPLACED FRONT PADS ROTORS AND SHIMS
SERVICE: CALIPER, BRAKE (FRONT) - REPLACE DESCRIPTION: ~|~CALIPER, BRAKE (FRONT) - REPLACE ~|~ ~|~137909 REPLACED BOTH FRONT CALIPERS INSIDE PISTONS WHERE FROZEN
SERVICE: COULD NOT DUPLICATE CUSTOMERS CONCERN DESCRIPTION: ~|~VEHICLE APPEARS TO BE SHIFTING ROUGH. HESITATING TO SHIFT AROUND 25MPH. MIGHT BE THAT THE VEHICLE ISN'T WARMED UP YET. CHECK AND ADVISE. ~|~ ~|~137909 NORMAL CONDITION OF CAR
SERVICE: SERVICE - 130,000 MILES DESCRIPTION: ~|~SERVICE - 130,000 MILES ~|~ ~|~133365 COMPLETE PERFORMED SERVICE
SERVICE: DESCRIPTION: CHECKENGINE (AND/OR VSC TRAC) WARNING LIGHTS ON; PERFORM DIAGNOSTIC TEST AND ADVISE ON RECOMMENDE ~|~CHECK ENGINE (AND/OR VSC TRAC) WARNING LIGHTS ON; PERFORM DIAGNOSTIC TEST AND ADVISE ON RECOMMENDED REPAIRS NEEDED ~|~ ~|~133365 P2445 SECONDARY AIR PUMP STUCK. NEED TO REPLACE VALVES AND PUMP AND RECHECK. VALVES ARE UNDER INTAKE AND EVERYTHING IS RUST ON EXHAUST MAY RUN INTO ISSUES. THIS IS STARTING POINT MAY HAVE DEBREE IN SYSTEM AND HAVE CLOG TO FROM INTERNALS COMING APART
SERVICE: REPLACED SECONDATY AIR INSTAKE AND VALVES. DESCRIPTION: ~|~AIR VLAVES BOTH BANKS/ AIR PUMP / GASKETS / TUBES WITH NUTS AND BOLTS FROM VALVE TO MANIFOLD /INTAKE GASKETS ................................P2445 SECONDARY AIR PUMP STUCK. NEED TO REPLACE VALVES AND PUMP AND RECHECK. VALVES ARE UNDER INTAKE AND EVERYTHIN ~|~ ~|~133369 COMPLETE REPLACED BOTH PUMPS, AIR VALVES, AND HOSES TO SYSTEM. FOUND VALLEY PLATE LEAKING ONCE DOING WORK. TEST DROVE IN CHECK MODE AFTER REPAIR AND NO PENDING CODES OR PRESENT CODES
SERVICE: REPLACED RUSTED UNDERCOVERS AND DRILLED OUT HOLES AND TAPPED. DESCRIPTION: ~|~UNDER SPLASH SHIELDS/BOLTS/ AND SUPPRORT BRACKETS THAT THE SHIELD MOUNT TO................SHIELDS ARE ABOUT TO FALL OFF RUSTED THRU AND BEARLY HANGING ON. PARTS WERE SHIELD BOLTS TO WILL NEED TO BE REAPLCED DUE TO BADLY RUSTED ALSO ~|~ ~|~133369 COMPLETE FOUND BROKEN BOLTS HAD TO DRILL AND TAP OUT HOLES FOR NEW SHIELDS AND SUPPORTS TO MOUNT TO
SERVICE: SEALED COOLANT VALLEY PLATE. DESCRIPTION: ~|~VALLEY PLATE RE-SEAL( NEED COOLANT FIPG, KNOCK SENSOR HARNESS, PCV VALVE BOX GASKET, FRONT WATER JACKET PIPE GASKETS BOTH, O RINGS FOR MIDDLE COOLANT PIIPE, 2 PINK COOLANT).......................................................FOUND VALLEY PLATE LEAKING W ~|~ ~|~133369 COMPLETE FOUND WHILE DOING AIR VALVES RE-SEALED VALLEY PLATE AND PRESSURE TEST AFTER NO LEAKS FOUND
SERVICE: GREASED STEERING BOOT. DESCRIPTION: ~|~CUSTOMER STATES THE STEERING WHEEL IS MAKING NOISE FIRST THING IN THE MORNING WHEN TURNING. INSIDE. SOUNDS LIKE SOMETHING NEEDS TO BE LUBED. ~|~ ~|~133365 AS FAR AS NOISE WHEN TURNING STEERING WHEEL. THIS IS ONLY A BAND AID BUT CAN TRY AND PUT GREASE ON STEERING SHAFT BOOT WERE THE RUBBER IS ON THE METAL SHAFT BUT OVER TIME THE RUBBER HAS GOTTEN HARD AND MAKING NOISE HAS STEERING SHAFT MOVES. WE CAN
SERVICE: COULD NOT DUPLICATE CUSTOMERS CONCERN DESCRIPTION: ~|~CUSTOMER STATES THE SHIFTER MECHANISM SOMETIMES FEELS STICKY. ADVISE. ~|~ ~|~133365 COULDNT DUPLCIATE CONCERN
