Long distance highway cruising
keep your 40 and buy an 80 for road trips :grinpimp:
/this\
I have done Omaha to Phoenix in the 40 - and numerous trips from Phoenix to Moab over several days
yeah, you are deaf by night time, your legs get a real workout, you can't hear the others on the CB, and if it's too hot outside, you are almost sauteed :hillbilly:
but, you get to sleep real well, accrue muscle strength, focus on the important stuff and take in the smells - not to speak of all the heads you turn and everybody wants to talk to you at the gas stations :grinpimp: [nothing of this happens when you drive an 80, just sayin']
I would do every single trip again :steer:
Could you post some more pics of this install?
Not easily. It's out in the rain under a tarp. :crybaby:
I have developed a little play in the wooden shim that I made that adapts the shifter outer diameter to the brake lever inner diameter, so I need to take it apart eventually. I was thinking that if I coated the shim in plasti-dip it would tighten it up and seal it against wear and moisture.
There are pictures in my 'after' thread of the e-locker circuit and the other end of the e-locker cable where it connects to the switch under the dash. I never did take a picture of how the bike brake cable attaches to the gas pedal, but I didn't fab anything there. The pedal has a lever for a cable attachment at the top as well as the rod linkage that passes through the firewall. It's a Toyota piece, but probably not original to this rig or even to a '76. In any case the brake cable housing is attached to an original bracket for a full-throttle emissions cutout and the cable just hooks into the top of the pedal. If that attachment point wouldn't have been so easy, I probably would never have gotten around to finishing the hand throttle.
