awesomeissquid
Nicely done!
I did rear main. The seller says the timing belt was 6,000 miles and one year ago. Inspecting the components I believe it to be true. Everything under the covers was shiny and new. They did not do the fan hub, however the hub on the dead engine was in good shape so I used it. SKF is the OEM on the racks that go into some of our Commercial trucks where I work, I trust them. Let's hope they hold up their end.I hope that aftermarket rack doesn't bite you in the butt. Not a job you want to do twice. The last two toyota racks I bought I'm pretty sure were south of $500 so not sure why you had such a high quote. I was thinking they were around $360. Perhaps I missed it but did you do the rear main seal? plugs? Coil packs? (they are notorious for failing). Timing belt? cam seals? front crank seal? hydro tensioner? thermostat? Did I mention 100s are maintenance whores? Is it time for rear trailing arms and ball joints yet?
I drilled the hole smaller than the threads, wrapped them in Teflon tape, and threaded the nipple into the plastic. The plastic is thick and pliable enough that it is very secure. Careful to not drill the hole too big, of course.No way to get that nut inside the air snorkel though.
Yeah I hit the button and I can hear relays clicking down in the passenger foot well but nothing ever moved. That was before the car wash and it was already bent a little.Hood flutter happens to all these trucks. If you look under the hood there are two rubber stoppers that you can just twist to adjust to make the hood seal up better.
Even beyond that, some hoods still flutter and most just live with it. Its caused by the glue sealing up the two layers of the hood separating
The power antenna - there's a switch to the left of the clock on your dash to raise/lower the antenna. Also turning off the radio lowers the antenna. If the motor is working for it, the mast replacement is relatively easy.
Antenna Mast Replacement - How To
Attached is a description and pictures of my 2000 Landcruiser antenna mast replacement. Symptons: Antenna mast no longer went up and down, but I could still hear the motor working. I ordered a replacement antenna mast for $52.99 including shipping, from...forum.ih8mud.com
Nice work on all this. I had very little to add except these little things:3000 mile update. All the repairs I made have turned out well. Oil pressure is low at idle which is unsettling but a manual gauge shows that it has about 8 psi at heat soaked idle which is within Toyota spec and clearly would have blown up by now if it was an issue, so I just have to learn to ignore the needle hanging out by the L mark on the gauge once it warms up. Contonues to drive nicely, no shaking or vibrations since replacing the front CV axles. I took it on a 900 mi round trip journey to Idaho a few weeks ago and besides drinking tons of fuel (13mpg with a 30mph headwind for a long distance) I am pleased with spending long periods of time at the helm. The only lingering powertrain issue is a check engine light for cam position sensor any time the engine revs over 3000 rpm for any length of time. Sensor replaced, timing verified and no driveability issue so I am thinking its a defective sensor or a wiring continuity issue. I intend to ignore it at this point it clears with 2 ignition cycles and driving like an old man around town letting it upshift at low RPM. I have also decided that the ECT Power button does absolutley nothing besides turn a green light on
