Attached is a description and pictures of my 2000 Landcruiser antenna mast replacement.
Symptons: Antenna mast no longer went up and down, but I could still hear the motor working.
I ordered a replacement antenna mast for $52.99 including shipping, from:
http://www.antennamastsrus.com/Toyota/Land Cruiser/Land Cruiser 1998-2004.htm
The first thing I did was unscrew the chrome retaining nut at the base of the antenna. Have someone turn the radio on and press the manual up button on the dash and gently pull the antenna mast and the nylon feeder out. If you’re lucky, the whole thing will come out and the replacement is pretty easy from there. In my case, the nylon feeder was broken off a few inches from the top, meaning the rest was stuck inside the motor. See the picture below comparing the lengths of the old nylon feeder and the new one.
On to accessing the motor:
First thing I did was remove the fender well skirt so I could access the antenna motor inside of the fender well. I used a small flat head screwdriver to pop out the fasteners. I don’t remember how many there are, but its quite a few if you want to get really open access to the motor. I also found it easier to jack up the LC and remove the tire to have more room to work.
Once underneath the fender, there is one bolt that holds the motor against the fender well.
See picture of anntenna motor attachemtn and black arrow (I'll post picture later once I figure out how to post more than 3 at a time???)
Once unbolted, disconnect the electrical connection. Note my motor was covered/protected with a plastic bag which I pulled up towards the antenna housing so that I could access the motor.
At this point the motor is still not easily pulled away from the fender well as it is still connected to the antenna wire. The antenna wire is connected via a black clip to a bracket which connects to the motor. The antenna wire runs under the fender back towards the dash/radio and there isn’t much slack in that wire. So it’s tough to work with the motor unless you free it up somehow. Rather than mess around with the black clip, I just chose to disconnect the bracket from the motor……which enabled me to fully pull the motor out and work with it freely.
Once you have the motor out, unscrew the five screws on the face of the motor (see picture). Be careful with the center screw as it has a tiny nut mounted on the back side which unless you’re aware of it can easily drop loose and end up in those infamous driveway cracks never to be found again.
Once all the screws were out, I gently pulled the face off the backing plate to reveal the inside of the motor. Gently pull out the old/broken nylon feeder that remains inside and that’s it. Put the face back on and reverse the order of the steps above to get the motor back in place and fully connected.
When everything is put back together (except for the chrome retaining nut), insert the nylon feeder into the antenna base while someone else presses the antenna down button on the dash. This will draw the feeder into the motor. Then turn off radio so that it fully withdraws into the base of the antenna. Note: I had to turn the radio on and off a few times before the antenna mast fully extended. Good as new!!
Hope someone finds this useful.
