location of power door lock relay
location in bj74?:
I've search under the dash, and no luck.
ideas? mine is blown out (tested door circuit per fsm).
before I tear into the rear cargo panels, does someone know for sure?
if i remember correctly bottom of drivers door... pop the panel and look about 3 " up near the front...
unless it's behind the power window relay, or its under the plastic- I can't see it.
I think someone said (or fiche shows) that since it operates the rear door as well it is in the cargo area behind a panel.
again, looking for power DOOR LOCK relay
