Has anyone had any luck sourcing pre-1990 wiper blade arms for an LJ70?
(LH) 85190-90K03 & (RH) 85210-90K03
Not sure if a 1990 or post 1992 wiper arms from an LJ, KZ, or HZ would have the same angle at the base of the arm or not.
I pulled a pair from the wrecking yard from an early 4Runner and although the lengths are approximately the same, the angle of the arm base isn't even close to an LJ70.
The bottom pair are from an LJ70 and have about a 30 degree angle and are taller at the base.
The top pair are off and early 4Runner and are straight at the base and are a bit more shallow at the base.
If anyone has any ideas what may work, most appreciated.
Thanks.
Don
Thanks.
Don
