Correct just drilled for 5/8 . Now you understand why i pulled the Tub off on Blue build . You have 2.5 months to get it done. Get after it !!!So you did not add anything to the adjustable upper, just drilled out to 5/8 ?
Modifying the rear aux tank is next, then frame cutting, but moving all the crap I wasnt expecting is gonna burn up some time. Fuel pump, filters , wire loom to rear, fuel lines , seemed easy until you crawl under there and realize you need everything in the tool box 1 tool at a time, up, down, up, down, knee replacement anyone........
Yes, it sounds like I am am going to love it. When do I get toSOA, custom Alcans, hybrid front axle with a 9.5 LC center and dand 60 from the inner C's out. Custom semi float dana 60 out back, put a 2001 LS lq9 in back in 06' IIRC, sm420, orion, arb's both ends, 120W of solar, sits outside 24/7 since 2000, aluminum roof skin front 1/2, polycarb 8mm double wall, tinted back 1/2.
Pics of the junk when I get started. Oh yeah. e2000 frame rail fuel pump with ford filters & a ford dual tank switch valve. Your gonna love it.
