- Thread starter
- #21
well poop i have no idea. I have not removed any of the valves to see if one is bent. I honestly have no clue without taking the bottom end apart whcih is happening soon.
wondering if you ever resolved the ticking, i am having having the same problem. Got a great deal on a 94 and was told the ticking was excessive lifter clearance. I looked into it and installed a couple new shims but the tick persists. Before I bought the truck it sat for quite awhile.
I have the same problem Mine only sat for maybe 4 days while getting repaired (and now ticks for days ...was told I need a valve adjustment so that will be what Im getting. Before i take the plunge I will get a full diagnostic to make sure I'm fixing the right thing Motor has 211,XXX miles
Reviving an old thread but I have a thought about this. Snowruns had a PS pump fail on his '94 and we learned the PS fluid gets pumped into the engine when the pumps fail. While ATF isn't the worst thing to run through an engine, it sure cleans stuff out. He is experiencing a very audible tick in the valve train after the pump was rebuilt. Assuming a bearing hasn't spun, the varnish might have been enough to mask a valve train tick prior to the cleaning.
Interesting. This all happened after i had a power steering hose (high pressure) blow and i replaced it and rebuilt the pump at the same time. So maybe you are on to something.
How does the PS fluid get pumped into the engine?![]()
I swapped out the filter and oil with no real effect.I guess my next step will be to have the valves adjusted. I will report back my results.
On his, the seal behind the gear was leaking. We kept topping it off to get him home and noticed the ATF wasn't ending up on the ground. When he got home, the oil was red and about five quarts too full.![]()
So I took the valve cover off and went through the FSM procedure for checking the valve shims and everything was well within specs. I also checked the timing and belt tension and everything was fine.on a serious note, it may be a good reason why my engine inside looked amazing for the mileage. I thought it was just from good maintenance and M1 syn oil use, but maybe i had a little extra help towards the end that i didn't know about.
I still however have a pronounced tick. On a side note the ATF did a really good job of cleaning the inside of the engine. I of course wouldn't recommend it as it causes a ticking noise.![]()
