Does anyone know a lift kit that is compatible with a BJ46?
The 44, 43, and 46 all have longer rear leafs. FJ40 rear leafs will NOT work. Check out the company ALCAN, they do custom work. There is another 44 on MUD that had the 4" lift done by them.
Hi All:
Also, talk with Kurt at Cruiser Outfitters, he could probably help you order a mix n' match set of OME springs and shocks to suit your rig.
Regards,
Alan
60 springs are wider IIR and I believe the 45 springs are a match or a close match except the 45 spring will probably be on the heavyside if you are looking for med to soft ride.
I found some tires online; I like the way 33x9.5 look. Does your rig have any lift at all?
Goal is medium...![]()
Cool, I'll go ahead and order my tires...I found them for 131.00 online and 70 freight...No lift on mine
I have thought about it several times though ,I would like to see what 35s would look like but would need a 4" or a SOA
I'm the guy with the 4" lift from alcan. I went with alcan because a 4" was hard to find in kit form.
You essentially have the 81 and later springs all around, but the fronts are the standard and the rears are 45/47 springs dimensionally. if you are looking for a 2.5 inch lift, go with the Old Man Emu. Kurt can help you out tith that kit. If you want higher, you can call alcan and get the same springs I did.
Hi All:
Regards,
Alan
^^THIS.
Kurt will know what you need. Also, OME is simply awesome, IMHO. Makes a cruiser ride like a caddy...
Dan
