bj46 power steering tubes
CH
Hello guys
I've finally decided to start replacing the power steering tubes on my 1983 bj46.
There's still a whining noise that I've not managed to get rid of by bleeding the air and replacing the fluid. I read on here for a similar case that there is usually a leak somewhere along the tubes or connector clamps.
My question is now regarding the parts - do you usually go with the original tubes (i'm looking to order from amayama) or is there a "commonly used" replacement product that does the job equally well?
Has anybody done this recently and could confirm that I will be needing the following parts:
Hose, Pressure Feed44411-60180
Hose, Return90445-18137
Hose(For Reservoir Tank Inlet)44412-60020
Tube, Return(For Steering Gear Outlet)44416-60070
4x Clamp, Oil Cooler Hose90460-01001
Any further recommendations on what to look out for would be highly appreciated.
Thanks.
Cheers Markus
Hello guys
Thanks.
Cheers Markus
Except for the clamps and 90445-18137, none of the other parts are available from Toyota anymore. Used or make your own.
