SOLD Lhd ute/pickup blue/grey flooring
Anchorage, AK
Looking for flooring/carpet/vinyl for a lhd ute/pickup. Pictures are of a late model 79, you can see how off the holes in the center are so doesn’t really work unless I just cut that part out and not put anything there. Wouldn’t look nice/finished though. New so far are unobtainable as far as I have found. Thanks
Air bag truck......really late model. R151 trans. Tough to make that one work. The closest I could get was a 2009 or so....still an R151 but it didn't have all the other cuts on the left side. Maybe a custom console to hide all that stuff.....
Those floor covers are cheap enough on mine truck take-outs that it would be really easy to cut one out and make a snap in trans cover.....maybe use the one you have if you can find a 2009 take out one without the cutouts on the floor. We were going to do that on mine but By the time I got my console in and made a patch, you couldn't see anything. Took a lot of work. And that pre-Rav-4 dash floor cover.
I think that was easy to get. Maybe. Going to PM you.
The front mat, Color code "03" is Shadow Gray and the rear mat you ordered, Color Code "B0" is gray. Not sure how different they are but I'd guess "gray" is what you have in post #1.
I ordered 58510-90L01-03 and 58540-60A10-B0 from a US dealership. Will see if they come through. Interesting that the second part number does not show up on amayama or partsouq.
Was the front mat price tolerable from US dealership?
Here are the two part numbers available from TMS, USA.
Color is very close. Texture is slightly different.
The 2nd piece under the seats needs to be trimmed on the sides as they are slightly too wide (for a 79 series). Once you trim the sides, the seat bracket openings are pretty close— I just opened them up a bit and was a perfectly fine fit.
-60A10 will most likely get cancelled. You need HS-7 documentation to get that part released.
Oh man.....always something. what's the process for the HS-7? Can I just print one out and fill it or is there anything specific that I need to know to fill out properly? Seems like I had to fill one out for the 12HT? Will need to look back.
