Builds Lexie/Land Bruiser Restoration Thread
Part no. 8499910310 for the AHC bulb. If all yours are out, it takes 3 I believe.
Side note - anyone have the part number for the hazard bulb? I pulled it apart and only found one long bulb that seemed like it lit up the hazard, antenna and CDL switches. Now none of them light up...
My dealer just told me that PN has been updated to #90011-01018 for the ANC bulb (used other places too) and when I go pick it up I'll see if they can find the PN for your hazard switch bulb. Somewhere I saw mentioned it takes a "T4" style bulb but that wouldn't be in the correct base for you.
I thought the 2002 & 2007 grills couldn’t work without modifying the surrounds.... so it just bolted up with ZERO modifications and it sits flush with fit/finish oem?
Yep - it's the 98-02 grilles that aren't backward compatible and need modifying. Any grille from 03-07 is interchangeable. More information here on LuxCruisers
The dealer wasn't able to locate a part number for the hazard switch, didn't show one on their diagram. Reminds me of the time I went to buy a running board light at Lexus and they said they don't sell it alone, I need to order the whole running board to replace a blown bulb. Thankfully the parts guy handed me a post-it note with the type of bulb from NAPA that worked.
Reading through your post randomly, I was inspired to call Lexus corporate about a debacle from a few months back where they broke my AHC to the tune of like $4600 and refused to do anything about it. Initial phone call went well, I’m hoping it pans out same as it did for you. Thanks!
Good luck! They were very helpful and it was resolved the day after I called.
Lexus Corporate just told me they really only deal with warranty issues and since I’m so out of warranty, all they can really do is facilitate a conversation between me and the highest management at the store that did the work. So we’ll see how this goes…
I guess that’s not exactly what they told you?
Well, mine was a botched recall repair, which may have been why it was resolved so fast
I've had the old girl for a year today, so I thought it was fitting to repaint her sad looking side mirrors. Used paint matched by automotivetouchup.com code 8P6 for Vapor Blue Metallic. I was hesitant because silver is a hard color to match, but I'm thoroughly impressed with the results! A rundown of my process for anyone interested in doing something similar is at the end of this post
To paint the side mirrors:
1) Mask off the area really well. I decided this would be easier than removing the mirrors from the truck.
2) Wet sand the mirrors with 600 grit paper
3) Dry with a microfiber towel, then wipe with alcohol to dry thoroughly, and follow up with tack cloth to ensure no dust particles are left.
4) Spray with 2-3 coats of primer, waiting 10-15 minutes between coats (it was about 40 degrees outside so my wait time was a little longer)
5) Waiting an hour after the last coat of primer, wet sand again with 600 grit.
6) Wipe with alcohol and tack cloth again
7) Apply 3-4 coats of paint, waiting 10-15 minutes between applications.
8) Let dry for 30 minutes to an hour
9) Apply 3 coats of clear coat, waiting 15-20 minutes between coats
10) Let the final coat dry for an hour, then remove your tape and admire your new mirrors for less than $50!
I did the same weekend refurb on my vapor blue side view mirror, original owner had hit it and cracked complete pieces of the plastic which looked horrible.
$150 shipped for a side view mirror from classifieds, pulled door panel and back to pristine!
I am considering the same touch up company as recommended all over these boards for retouching a roof rack medium gray, or changing it to vapor blue metallic.
Did the vapor blue have the metallic flakes which makes it pop?
It’s been overcast here for a while, but even in the shade it still pops. Good idea about the roof rack though; mine is all scuffed up and I still have some paint left. I think you just gave me my next project...
In pics it looks great. My lower cladding is body color, IE not two-tone, and starting to show CC failure.. Do you think it would be feasible to use this same product to respray the cladding and have it match well? Mirrors are smaller and easy, just curious what your thoughts might be having used this paint on covering a larger area.
I wouldn't use it for body colored cladding - the clear coat isn't as smooth as factory obviously. On the mirrors that naturally contrast the body due to sticking out, it isn't noticeable. I think cladding would stick out more. I have two tone cladding/body and am thinking about spraying the cladding though, since there's nothing else for it to match.
Where did you get your paint and primer at? What brand? all that info..
Thanks,
-Aaron
Thanks,
-Aaron
Paint from automotivetouchup.com, the rest came from Home Depot. I tried the high-fill primer that was supposed to fill in imperfections but I didn't notice much of a difference. Brand/type of primer isn't super important I don't think. I used clear coat that is meant for plastics and UV resistant: Rust-Oleum Painter's Touch 2X 12 oz. Gloss Clear General Purpose Spray Paint-249117 - The Home Depot
My mirror base is chipped on one side but I was just leaving it be saying to myself, "it's a truck" but now I think this is on my springtime list once it warms up again. Very impressed how well the section where the mirror body meets the base, not all gummed up with paint. I guess the trick is to go light in that area?
