LED light bar - Lense questions (1 Viewer)
Redlands
I have a 30" LED light bar, from Arsenal LED on pirate4x4, and I think he is on here as well. It's a common Chinese kind, looks like most of the others out there.
Anyways, I have a flood pattern now, but would like to go with a combo pattern.
Does anyone know where you can get the lenses for the LED light bars?
If the light bar can be disassembled, you can open it up, take out the lens, measure it and have some new ones made up in most plastics shops for cheap. I had some replacement ones made for my Rigid Dually LEDs and it cost me $3 to make 10 polycarbonate lenses. Quite cheap. I assume your flood pattern is just a diffused lens, so a clear lens should solve your problem.
If you can't open the bar, you're probably SOL.
You probably need a different reflector, not a different lens. Most less expensive Chinese light bars use a different reflector (behind the LED) to specify the flood vs spot pattern, where as some pods will have a diffused lens to make a spot pattern turn to flood.
That's what I am thinking, I just need to find a place where I can buy the reflector. I know the entire front lens can be removed, along with the reflectors.
I doubt you'll be able to. I can't even get them for my Rigids. The only lights I know of with changeable optics are Baja Designs and Heretic Studios. I'm sure there are others, but I haven't seen any.
Edit: Nevermind, you might be right. In the link you posted, it says they're serviceable, so you just have to find where to get them. I'd guess the manufacturer.
Yea, I kinda figured I would have to find them from there, just hoping to get a lead on a better place. I'd hate to havw to sell this light and buy a new one.
The same light bar is sold by a lot of companies under different names, so maybe you could find a smaller, cheap spot beam bar somewhere and change out some of the reflectors. Maybe get a 12" or 20" bar, swap your center reflectors to spot and end up with a combination bar. Swap the flood reflectors back to the smaller bar and sell the bar as a flood. Probably easier than finding the original manufacturer and getting parts. Probably cheaper in the end as well.
Thats a good point, I'm going to try and look around and see what I can find for reflectors. I could always sell the 30" and go with a 40" combo... but who knows!
There's no such thing as too much light, but that's dangerous logic right there. Trust me, I know, it's expensive logic sometimes too. Why settle for a 60" TV? Why settle for 35" tires? Why settle for 40,000 lumens on the front of your truck? :)
I try to explain that very thing to my wife...
I just bought a cheap 50" bar off ebay, combo beam (8 degree / 90 degree), it's the epistar LEDS (96 3 watt). Thing put out a RIDICULOUS amount of light, across from my house is a straight maybe 1/8 mile section of wide road, lights the entire thing up like high noon. Advertised 28,800 lumens.
