Lean to the left after lift
Missoula, MT
I searched on this and there have been some examples but nothing I saw that was totally definitive, and I am high maintenance.
I now have heavy springs installed front and back. The front is even, the back is exactly 1" higher on the PS than the DS. I checked 4 times and the "B" spring is on the DS and the "A" is on the PS.
This is with a full tank of gas and the lift has been on there for under a week. I put the 4x4 labs bumper on it this evening, I did not think to measure the lift prior to that. There are no swing outs on it yet so the weight ought to be pretty even.
Problem? Am I over thinking this? Should I leave it for a couple of weeks, drive it some, and then worry if it is still there after the springs have a chance to settle and the swing outs are installed? It drives fine. I can always add a spacer if I have to but that seems like it shouldn't be necessary.
I'd get the swing outs on, get some gear in it and see where it sits. You may need a spacer or two to get things leveled out just so.
I have the same problem, but I need to get a rear bumper on and the winch mounted up and see how she sits.
I have the SLEE 4" kit. My rig never seems level and it bothered me at first. Then I figured out:
If I go from Drive to Park, my drivers side will sit a little higher.
If I go from Reverse to Partk, my passenger side will sit a little higher.
I may have that swapped, but you get the point.
I am 1000% sure the B spring is on the DS and the A spring is on the PS so they are installed on the correct sides for a LHD rig. I looked before the install, and checked again multiple times before reassembly, and again after I noticed it was not even. This particular instance is not a case of the springs being on the wrong sides unless they are labeled wrong.
aren't the front springs and rear springs supposed to be off set? On the front the b is on the DS but is on the PS on the rear. ARB told me that you need to make sure the "A's" aren't on the same side.
yes they are. again, in a RHD rig the A springs go on the DS and the B springs go on the PS. In a LHD it is reversed. I installed them reversed, therefore the springs are in the correct spots for LHD and that is not the problem. I may have installed them incorrectly where one is not seated right or something which I will check but they are most definitely, without question, on the correct sides of the truck.
Then it has to be a weight distribution issue. I have a swing arm and heavy spare (315 MT/R) hanging off my IPOR rear bumper on the driverside and a Hanna Interior cargo rack with a jerry full of water in it on the driverside as well...had a lot of driverside lean as a result. With J's in the back, I still needed a 25mm spacer on DS rear to level everything out. I know you say it seems like weight is distributed relatively evenly...are you a large man (lbs?) I am, and adjusted accordingly. Swap the rears and see what happens...
I had the same lean with my 2.5 Old Man Emu lift heavys on the front and medium on the rear. I ended up ordering a 1" spacer from Man-a fre for one side and leveled things out. My front was fine.
I have the same problem with the Ironman. I contacted the distributor and he told me to put the the way they are marked; DS on DS and PS on PS. I haven't got the time to do it, he did it on his Lexus and worked. :beer:
I also have the same problem. Stock 92 with Ironman. Put the tallest spring on the Drivers side had about 3/4" lean as I recall. Swapped the springs and more than a 1" lean. Swapped back and added a 15mm trim packer to the driver's rear and it's within 1/2" now. Probably should have went for the 30mm.
Long story short, after reading about all the aftermarket springs/lifts, they seem to all have the lean. You will need to make sure the tallest spring is on the driver's side and/or add a trim packer to make it closer.
I know this is an old post but I have the same issue. I swapped the springs in the back and still no different (leans to the left). I think it has to be the panhard rod. When I install an adjustable one I will know for sure.
Give it some time. I initially had this driver side lean when i installed my lift. I checked it yesterday, after 6 months or so, it is perfectly leveled left to right.
Did an adjustable panhard rod make a difference? I just swapped my ironman springs (installed backwards initially) and I'm still 1" lower on DS. I still have stock panhard rods and am thinking this might be an issue...
I have a rear bumper w a swingout and the 35" spare mounted up there. I took the spare off with no noticeable difference in the lean.
