Atwalz
Civil Engineer
Yesterday, as I left home, I heard click sound. I pulled over in the parking lot to check the suspension. It was dark and could properly see what happened. As I started to back out, my LCA separated from steering knuckle. I had truck towed to home. Later inspection revealed that it was a ball joint failure. I am lucky that it happened at low speed and parking lot. I am not going to speculate how it failed and how long it was like this. It had an initial crack and then final failure. So don’t ignore suspension sounds. I typically inspect all fasteners visually if anything is loose. But in this case, it was not discovered during visual inspection. I am replacing both LCA with OEM tundra.
