This is the first I have heard the 4Runner is getting the 9.5”. I thought it was still the 8.2” found in the 250?That's interesting! The curb weights are so similar - I wonder if the weight reduction efforts were worth the effort and cost of doubling all the tooling, engineering, etc. And - would be intersting to know how the 300 compares to the Sequoia and Tundra. And I suppose also to the 4Runner with the 9.5" rear axle.
Some trims get the 9.5. I think it's hybrids without AWD. I can't remember what Tacoma trims have the 9.5, but id guess it's the same combination in the 4R.This is the first I have heard the 4Runner is getting the 9.5”. I thought it was still the 8.2” found in the 250?
Who buys a 4Runner without 4WD?Some trims get the 9.5. I think it's hybrids without AWD. I can't remember what Tacoma trims have the 9.5, but id guess it's the same combination in the 4R.
Blasphemy!Who buys a 4Runner without 4WD?
That is literally what the video shows.That doesn’t mean weight and strength were taken out.
It’s inferring that the components were made inferior when they weren’t. The specs are different because it’s a different vehicle built for a different purpose.That is literally what the video shows.![]()
I wasn't very clear in my post. It would be the part time 4x4 models with the hybrid. The AWD models have the 8.2" rear axle because power is split front/rear all the time.Who buys a 4Runner without 4WD?
I would rather have the 9.5 as a nice intermediate axle size. But the 8.2 might be considered superior if it is strong enough to not bend or break and lighter. Just needs to be fit for purpose. I don't think anyone would want a Rockwell under there. Even the Tundra 10.5 probably would be worse for a 300 or LC250.So then, thinner and smaller don't mean "inferior", just different. Glad we cleared that up.
Toyota made the lower control arm frame mounting points different.Now the big question… can we take a Tundra front suspension/knuckles and bolt it on to the 250? An easy and cheap +2” suspension arms with HD knuckles and probably wheel bearings. Or did Toyota put up their typical road blocks by changing things to prevent an easy swap?
That would be such a better point if that's what was being compared. But it's not so it's irrelevant. Making the case that it's good enough may however be relevant if that's was the topic of the conversation. But it's not. The only relevance here is the two very specific things being compared and there one is obviously superior to the other.It can be superior or inferior. The size or strength isn't determinative of that without an application. A Rockwell axle isn't superior to a Jimny axle. It's just different. In this case the 8.2 has more ground clearance and weighs less. Both are objectively better if the axle is strong enough otherwise.
The Tundra\Sequoia arm mounting points were like an inch wider than the 250.
The 9.5 is stronger. For an LC250 - I would choose the 9.5 over the 8.2 because I would want to use it in a lot of ways Toyota does not intend it to be used. I'm still a bit skeptical of the 8.2 on a 5500lb SUV with 465 ft lbs (although I suspect it's not really 465 in any of the lower gears).That would be such a better point if that's what was being compared. But it's not so it's irrelevant. Making the case that it's good enough may however be relevant if that's was the topic of the conversation. But it's not. The only relevance here is the two very specific things being compared and there one is obviously superior to the other.
