Hey all,
I recently stumbled across this site looking for info on kzj78's because here in Australia there was only a few imported, so there is little to no info locally (although toyota list parts for them, which is a bonus) and I'm one of the lucky one's to own one
Although it's not registered at the moment
I do have a few questions though, I do eventually want to put a snorkel on it, can some one please tell me an exact other cuiser models will bolt up ( i doubt i will be able to ask for a 78 series one)
I also would like to lift it ~4" or more, I came across a thread on here that says you can use 80 series rear coils in the front of the prado, which gives ~4" of lift (although the spring rate is different), what then do people use in the rear? is there any other model cruisers that uses the same diameter coil & a similar spring rate? And what length shock do people then use?
Does any one know what other models share the same diff centres? I'm planning on running 35"s in the future but i want to lower the diff ratio's to take a bit of the strain of the box and keep low range reasonable low. I know you can change the transfer ratio's but i think diffs maybe a cheaper option, depending on availability.
No doubt i'll have heaps more questions when I finally get it on the road, hopefully not long now, just need to sort out tyres and the injector pump (going in on monday to be fixed
) any info would be greatly appreciated
