A couple weeks ago I had Discount Tire do a 5-tire rotation of my KO2s and rebalance them. It had been about 6500 miles since they were originally installed and balanced and this was the first rotation. Their first shot at balancing was not right and I could feel it in the steering vibration and a bit of pull to the right. They rebalanced and admitted that all 4 tires had been off due to some issue with their machine. After the rebalance, the steering vibration and slight pull were gone but they still don't feel near as smooth as they did before I took them in to DT.
Aside from taking them back to DT, anything I should be looking for? I have a couple ideas but I don't want to lead the witness.
BTW, I am going to put some P-rated snow/ice tires (probably Haks) on before a couple of upcoming, pavement-only, long road trips through Wy, Mt, PNW, etc. where snow is a given and ice likely. But I would like to sort out the KO2s before I put them back on in April.
Update: Looks like the problem is solved. Discount Tire had not been using what they call a "finger plate" when doing the balance. These are important when attempting to balance Toyota wheels. @bamma pointed this out be referencing the Haweka adapter. I pressed DT on it and uncovered that they had these finger plates but the guys doing the balance did not realize they were important to use. (Their manager set them straight once he understood what was going on.) They re-balanced them using the appropiate adapter and it appears to have addressed the issue. Still doing an alignment check tomorrow but feeling much better!
