Hey there all, im going to do my front axle and have come across a ton of info while searching. Can anyone recommend their favorite rebuild kit along with any pros and cons? thanks in advance.
Assuming you mean a Knuckle rebuild? Call Cruiser Outfitters, they can get you exactly what you need. Do you know what tools and supplies you'll need?
Yeah. Knuckle. SOrry bout that. I’m not going’s to do anything but the knuckles. I’ve got the basics as far as tools go but I have to grab job specific ones as well. IE I have torques , ratchets and a garage that’s about a 3 out of 10 in regards to being outfitted. This gives me a reason to start buying more tools.Assuming you mean a Knuckle rebuild? Call Cruiser Outfitters, they can get you exactly what you need. Do you know what tools and supplies you'll need?
Thanks so much. Great info. Appreciate your time.This is the correct answer. Call Kurt and all your problems will be solved. Joking but seriously call Cruiser Outfitters, at least for knuckle rebuild parts. Its as painless as can be. His kit includes everything needed and he can include either the OEM inner axle seals or the Marlin ECO seals if you prefer. Not sure your situation but if you don't have it the 54MM socket can be sourced from him. If you want to replace the brake rotors while you do this Kurt can source those too. If doing that you may want to source the wheel studs from CO as well. Good idea to replace from what I am told. In the middle of this right now using a CO rebuild kit. HTH.
Thanks for the info. Appreciate itget the "kit" from either:
Kurt @ @cruiseroutfit
or
Georg @ cruiserbrothers @orangefj45
both will treat you very well
use Marlin heavy seal
+1 on the Marlin seals. I'm going on 4 years since I did mine and everything is still high and tight...get the "kit" from either:
or
so this is the exploded image from the proper manual right? the next image is the tension gauge which should be at 6.6 to 13.2?Also 10, 12, 14, 17 mm sockets and 19 or 21 for the king nut on the tie rod end of the knuckle. A torque wrench, A brass drift to knock the cup washers loose and a tapered drift to knock out the trunion races, A tub of wheel bearing grease for the wheel hub, some moly grease for the knuckle, a box of latex or nitrile gloves, about 4 rolls of paper towels, a 2 inch pipe about 10 to 12 inches long to drive the new axle seals, or a long drift. Read over the body and chassis fsm for the procedure and to get your torque specs, and watch a few videos in the FAQ section. If you don't have a seal puller a long thin pry bar will get the axle seals out. Keep your knuckle shims in order.. Don't get them mixed up they need to go back the same way to keep the knuckle centered. A spring fish scale helps to determine pre-load on the knuckle and wheel hub.
Brake Backing Plate Gasket- $5.50 each Between brake backing plate and spindle One required per side, 2 per axle (Fits 69-9/75' FJ40/55) Part# HG60010 Brake Backing Plate Gasket - $5.50 each Between brake backing plate and spindle One required per side, 2 per axle (Fits 9/75'-97' FJ40/55/60/62/80) Part# HG60011 |
This is why I bring this up. I think the image of the schematic is confusing. The FSM literally says to install: the gasket, the dust cover, the dust seal. (and I assume in that order)I did mine like above and like the FSM. Seems there should be a seal between the dust cover and spindle though and the cut out in the seals seems to make sense. Not sure which is correct but when in doubt I follow FSM.
