Jealousy will get you nowhere.
You got a link to your build thread on pirate Mr. Bolt On?
Caster numbers seem good and right in spec. But shooting for 5*?
A job well done indeed. I'd love to see a post cut/turn shot with the same level gauge readout. I think that'd close this thread up nicely.
I am impressed that he just did it. I have those tools, yet I would be very serious (nervous) about making sure I get this right if I attempted it. Cool to keep the pinion angle correct. Nice.
I believe it ended up only being 3/16" or 4.7625 mm for the rest of the world.![]()
Hero? I don't think so my friend! I am going to get down to your part of the world one of these days and wheel with you and your crew.
ISo it is time to fire up the welder and dial in your heat and speed. Then burn the weld into where you made the cut. ...
You do want to have a full penetration weld here and if it was quarter inch wall pipe, you would have a 60 degree bevel and something like an 1/8 inch land and root gap. On FJ40 axles, I have seen people grind out the cut to approximate these conditions before welding.
It would not be easy to get full penetration with a butt weld with a 1/16 gap, so if you just want to weld it up after cutting it with no further prep, then you would want to mock this up and weld a test piece first to see if you get full penetration. It is not something you would want to assume.
For that matter, I'm a big proponent, but this isn't a cut and turn, by definition, but a caster correction by rotating the knuckles.
Not sure about that. I always understood cut and turn to be exactly this.
damn .. gotta check my glasses .. anyhow if you would have the chance to do it again, would you aim for more caster .. something like 1/4" ..?
you are very welcome .. just let me know when .. and BTW 30 hours .. damn, still very good .. ( no hero)
He says at the beginning that he couldn't rotate any more because the steering hits the control arms.
Yes, they were cut away and yes they were turned, I'll give you that, but insinuates correction of both caster and pinion angle and I'm, again, a huge proponent of.
Someday I'll "do it right" by exactly that.
Correct caster by OPs method of rotating knuckles in the axle ends.
Correct pinion by rotating entire housing to a perfect 0 degree variance from output flanges.
Run OE joints at both diff and TC, since now they're perfectly parallel, a departure from OE, which are not.
It wouldn't if the entire housing were corrected.
One more time, before ANY of what I'm saying is misconstrued.
I applaud KrazyToy's efforts.
Beats mine, of which I'm all but embarrassed of.
I forgot to mention that I pre-heated the area with my torch before I welded it. I am very confident in my welding skills and I am not worried about my weld breaking. I have welded much more critical stuff then an thin wall knuckle, but you do bring up a good point that this is critical area and should be welded on only by qualified individuals.
