Glad to see everyone using this thread as a small resource. A lot of knowledgeable members contributed to this thread. Honestly this is a repair that seems like it happens way to frequently with the 3urfe in the 200 series (if you own a 200 and haven't dealt with this yet, consider yourself lucky..lol). Maybe @Romer can sticky this thread in the 200 series FAQ in Repairs /Maintenance-Engine?
If my arm wasn't messed up, I'd tell you to swing by.. If you decide to tackle it yourself, I still have the Toyota Black Sealant left over-In Hayward.This is a great thread and resource. Nice work @kms254. Wish I had the time and a patient better half to allow me tackle this my self lol. Appreciate you documenting your process/progress.
I have a small leak at the valley plate and will be having my Indy Mechanic take care of this in a Couple weeks. What I find interesting is that both a Lexus dealership and a Toyota dealership claimed there isn’t a stated hourly rate for this job. Lexus wanted 12 hours and after talking with their service manager he said he would come down to 8 and give me a deal lol. Toyota claimed 6-7 hours shop time ($1,200 labor) and said their rate is based what they charge for removing the intake manifold plus a couple extra hours of shop time for the valley leak repair.
Well if I saved 1200 bucks, I guess I can justify the full set of bud built skids I just bought…This is a great thread and resource. Nice work @kms254. Wish I had the time and a patient better half to allow me tackle this my self lol. Appreciate you documenting your process/progress.
Right on, appreciate the offer @cc93cruiser. Hope that arm feels better. Good to hear from a fellow Bay Area cruiser enthusiast.If my arm wasn't messed up, I'd tell you to swing by.. If you decide to tackle it yourself, I still have the Toyota Black Sealant left over-In Hayward.
Untitled by Jeff Nada, on Flickr
Untitled by Jeff Nada, on FlickrThanks @Supra88 - I used the Aisin sealant that some others have used successfully. I doubt that's the issue as it would take a while for it to fail if that's the issue (Aisin FIPG Formed-In-Place-Gasket AB1207B1 - https://www.yotashop.com/aisin-fipg-formed-in-place-gasket-ab1207b1/). It's rated for the pink coolant and I applied based on the instructions (within 3 min of application, torqued at 10 min post application)
I did use two new o-rings and lubed them with coolant, use a new gasket for the check valves and even new gaskets for the coolant bypass
You did everything correctly. The decay isn't linear and that makes me think that it's not your sealant and more likely a hose. It appears that 13 psi is the threshold where it's allowing air or coolant to slowly escape. You'd think you'd see coolant though.Thanks @Supra88 - I used the Aisin sealant that some others have used successfully. I doubt that's the issue as it would take a while for it to fail if that's the issue (Aisin FIPG Formed-In-Place-Gasket AB1207B1 - https://www.yotashop.com/aisin-fipg-formed-in-place-gasket-ab1207b1/). It's rated for the pink coolant and I applied based on the instructions (within 3 min of application, torqued at 10 min post application)
I did use two new o-rings and lubed them with coolant, use a new gasket for the check valves and even new gaskets for the coolant bypass in the front.
