Is it possible that your tester has a slight leak? Did the 17 psi show any decay?
17PSI leaked down maybe .5 - .75lbs in 15-20 min. Certainly possible the tester is leaky... Borrowed it from O'Reilly.
Soapy water from a spray bottle will expose an air leak very effectively.17PSI leaked down maybe .5 - .75lbs in 15-20 min. Certainly possible the tester is leaky... Borrowed it from O'Reilly.
I unbolted the bracket from the manifold. I used a ratcheting box end wrench.how did you people remove the grey cables attached to the rear of the intake manifold?
It has two screws which are attaching the grey cable in two spots to the back. Its really tight and I couldn't figure out how to remove it easily.
Any tips?
thanks. I will do that.I unbolted the bracket from the manifold. I used a ratcheting box end wrench.
On assembly I attached the bracket but had the grey clip disconnected and then clipped it wile placing the manifold.
It is just like the gray clips on either side, there is a tab that you bend back and it will slide right off the post. The one on the back of the manifold has the tab on the bottom facing backward. Tough to get to but with a short screwdriver or oring pick it is possible mostly by feel.how did you people remove the grey cables attached to the rear of the intake manifold?
Any tips?
Reading that this is the sign of worn our PCV valve, so it should be fixed as I replace PCV valve.I saw the gaskets a bit oily, is it normal to have oil on the gaskets?
Isn’t the new super-expense sealant some kind of updated part? Toyota should have been aware of this before your rig was built so there is a decent chance they addressed the issue.Depressing thread, was hoping for better from Toyota, but thanks for all the good info and warning! I've had the leaky valley pan out of my BMW, and lifted the intake on my 100 to access the starter. Looks like I'll be doing this in 4-5 years on my '21? Getting older, not as excited about wrenching as I used to be.
Had the same leak going.
Fixed this week : Sealant of the heat exchanger cover.
2011 with 95 K miles.
Wished Toyota used better quality sealant on the heat exchanger cover.
Looks like same clip discussed here in 460 coolant valley thread
82711-2A620
