Builds Kimchi Build (1 Viewer)
ceylonfj40nut
Waiting for Barn Time
TX
Have not had much time to post on things of my own. Been busy with the boys (@SipLife and @Cowboy45) projects. Thought I would get it started. Rig is a 97 triple locked 80. 177k miles. Bone stock except for front bumper. Everything works. No rust. Clear blue title.
Bought it in San Antonio. Owner had a ton of receipts. Only issue was oil leaks from the common areas (front main seal, power steering pump cover, dizzy oring). Drove it to DFW topping it off every 100 miles🥴. It got me home. Nice rust proofing for sure.It’s a good start.
We are a cruiser family. Hope to document the journey we are on. As with most of these great beasts it is a marathon, not a sprint.
The name is appropriate. Rough around the edges. Smells like it at times.
The build plan will evolve with time.
First will be a good baselining.
I forsee V8 power in your future
Pffft
Saw this one for sale, was very tempted to snatch it up, but glad you grabbed it! Looking forward to seeing you plans.
On a side note, I know you almost grabbed the other 40th in SA as well and because of your interaction between the seller and subsequent post on mud, it compelled me to stop hazing him and actually reach out and buy it from him. So thanks!
His style was a little off putting to most on Mud, but he was a stand up guy when I spoke to him. Glad you got it. Timing just did not work out at the time. It was a good deal. You lucked out.
Ordered wits end front timing cover seal kit ( dizzy oring, front main seal, oil pump gasket, new hex screws, etc.). Also managed to snag a used HD 2.5” OME lift kit (40k miles). Will be adding bilsteins down the road if shocks are not great. Waiting for barn time.
Took a bigger bite at it today. Rubbing compound and wool pad followed by Griots.:princess: Also took to it. Its a good first cut. Going to try Graphene polish tomorrow.
Getting better. Its an art. Tried the maguires cutting compound and finishing polish. Tried various pads (wool, foam). Kept getting bake in of compound and polish. Looked splotchy. Also tried high end graphene infused stuff, no joy. Eventually went back to simple rubbing compound by hand and elbow grease to prevent “bake in” of compound. Then waxed by hand as well. No splotches. Deeper richness.
Good for now. Hood and roof will need to be painted. Rest will work for my needs.
Its been a minute. Trying to work small things in between other projects as I wait for parts. Brutus has had a nasty aftermarket alarm that has been causing havoc. Keeps going off and jacking with the main ign relay and fuel pump relay. Tried to start. No CEL. Found IGN fuse popped while on battery chargw. Restored CEL. Tried to start, crank but no start. Ripped out the alarm system. Still no start. Have spark, it started with starter fluid. Fuel pump relay and main ign relay checked out. So yanked fuel pump. Alarm triggering relays might have burnt it out.It’s toast. Learning as I go about PO. Looks like they replaced fuel pump with after market “Kenzo” pump. New Denso OEM pump and filter en route from Partsouq.
Needed new battery lugs. Brake bleeders were shot. Also got a power bleeder with toyota Master reservoir adapter. Trying to get brakes sorted, then oil leaks (dizzy and oil pump)
Is this unit running yet?
