JW Speaker heated headlights - Heaters failed prematurely (1 Viewer)
Spook50
Skål
Supporting Vendor
Spokane, WA
I have a set of heated JW Speaker LED headlights on my 62. Low beams and high beams. Loved them, but I had one low beam with a manufacturing defect that caused the heat grid to fail after only a year. Visible corrosion on a contact point inside the assembly. Got a hold of JW Speaker about it and they refused to help me since it was a month past the warranty, despite being an obvious manufacturing defect. Sour taste in my mouth already.
This morning, after only four years of use, I noticed the heater grid in my other low beam has also failed.
Needless to say I'm not happy with two $250-each units failing like this and receiving no support from the manufacturer over the first one given it failed so early. Unless there's been a change in process and support at JW Speaker, I won't be using their product for replacements.
Well that sucks.
