Holy crap! Turbocruiser is getting 13s and you are getting 9.8 running the boost under load? You keep running lean like that and y'er gonna blow that motor.My wideband was reading 9.8:1 on extended steady boost at 30% throttle. Most of the time I see low 10s under boost though. I will definitely be doing some kind of fuel control later. -Andy
It seems to be full boost at 2500 to 2600 RPM, I'm not running it very hard. You do hear the turbo more since it is at the back with such a short and large exhaust(4") after the turbo. It sure runs goodGetting on the freeway has never been this good! I'll take more pic's soon. Everything looks better underneath painted black. I can use some ideas on the intercooler pipe. My wideband was reading 9.8:1 on extended steady boost at 30% throttle
Seems to me that running rich at WOT is a *good* thing and I cannot think of a reason to change that. Kinda defines what WOT is all about doesn't it?
What am I missing?
-B-
What I'm wondering, and is probably more appropriately another thread alltogether is why the rig initially sets WOT at a more ideal mixture and then allows the constant creep towards richer?
I wonder if it could be due to a mismatch in the "curve" of the MAF versus the ECU's expectation.
This has been on my mind for some time. If that is the case then the answer would lie within the ECM, which I have a spare of.![]()
Okay guys group chant: "Crack It, Crack It, Crack It" !![]()
I'm the rookie here. In my mind, the different speed/rpm/load values would obfuscate the results.
I don't have WBO2, but I can hold most of the variables constant by going up a consistent, steep grade at altitude.
In Turbocruiser's case, though, he'd probably need to be towing 15,000 lbs up the same grade!
The only way *I* can think of to isolate down to 1 variable (boost) would be to buy some dyno time.
If it is this (10.8) rich maybe lower octane fuel could be used?
Just putting this out, but anyone have any thoughts that the engine was cammed for torque in the low rpm range (low rpm is it's most effecient point for fuel combustion) and that the engine is just really poor at combusting fuel at higher rpm? It may look rich on the wideband but the engine just isn't setup to combust the given fuel effeciently so out it goes to the exhaust? Just thinking out loud.
I beleive I've worked out why we're seeing a rich condition and why Toyota programmed it to do that. The explanation is heavily weighted on the theory side ...
... theory rarely applies to real world 100% of the time.
