Yep. That's how I learned.
Being inexperienced, slightly anal, and tending to strictly adhere to instructions - assembling a set of 5, 32 bolt beadlocks with a torque wrench is a chore I hope never to perform again. The only thing worse than the painstaking task of getting all 160 bolts lined up and started by hand so they won't strip the nut inserts and then properly torqued 4 times each is hovering over the tires, inflating them, and trying not to **** your pants when the bead finally sets.
Did you put your slide rule on these tires versus the 345's?
37" red labels?
Looks like you decided to keep the spacers on it.
Ok now it just needs to be tested in Katemcy next week!
This is looking like it might happen.
