- Joined
- Apr 17, 2009
- Threads
- 17
- Messages
- 2,669
- Thread starter
- #561
DAMN...I need to clean that thing! After several steering pump replacements, I think I've got about 6 quarts of power steering fluid all over everything down there.
Just take out one oil pan bolt at a time and put a dab of loctite in it. That's what I do. And it's the only way it should be done. If you loctite them before install, it'll never work. Loctite sets up pretty quickly. So when you're dealing with a setup like this, where you have a large quantity of bolts that need to be retorqued a few times, the loctite sets up and then turns to powder the next time you tighten the bolt.
So I get the pan on, go thru my torque sequence 5-7 times till the gasket starts to compress, then I remove one bolt at a time ( in torque sequence ), apply a little loctite, and re-install. Tedious and takes time, but it works.
Georgle
Ps: torque the pressure plate bolts to 21 foot pounds. No more.
I'm not doing any homework but I need mine welded on as well....Just doing some homework so I don't waste any of your shop time, brother.
