JT's FJ40 build (1 Viewer)
Me an' Todd can be on stand-by for a conference call.
Once you wrap your head around it all, the TBI system is pretty simple. With the basics covered, it should fire right up.
Thanks!
What did y'all run to the three vacuum ports on the throttle body...or did you just plug them?
Cool...that's what we've got. I've seen some where the larger of the ports is run to what looks to be the PCV valve, but we've got the PCV valve run to the factory location on the bottom side of the intake manifold.
Which fuel pump are you running?
If you find that it's too loud, and you have a few extra bucks, this one is silent. It's a low enough pressure that it doesn't overwhelm the TBI.
http://www.fuel-pumps.net/gsl395.html
The one that came with the AFI kit....not even sure the make or model. It looks identical to the one above, but I suppose they all look pretty similar.
jrob said:
Power Steering complete, brake lines complete, cooling system and hoses complete, fuel lines 90%, new battery tray installed, F250 shock towers installed, EFI installed, We need to finish up a few electrical items and run the fuel lines into a gas can and I think we are ready to fire her up! Still a ways to go to get thru. Hopefully Saturday or Sunday we can get her to idle!!!!
Powerful stuff
We connected all the wiring, added water and coolant, dropped a supply and return fuel line into a 5 gallon can, primed the fuel system, and she fired right up. Initially she would die right after starting up. Turns out one of the injectors was a little clogged. After we blew it out she ran like a champ. Still needs a slight timing adjustment, but she lives:
https://www.youtube.com/watch?v=66dz5nhZmSY&feature=em-upload_owner
Good day today...REALLY good day.
For Bomar:
Awesome progress!
Anybody want to come over? Feel free. We will be on it again today.
Bomar would have helped but he was doing this!
A few updates and a gallery of Jrob fab shots.
Anti-wrap bar...upside down with paint drying:
Wrap bar front and rear supports:
