Jowett Performance Filter Housing with Fumoto drain valve (3 Viewers)
In for the GB!
In the midst of installing Jowett’s cap and doing oil change. Support tube has been transferred. It’s pretty loose with the tabs down. Won’t come out, but wobbles. Am I missing something?
The spring?
Along those lines, anyone have any input as to if you run the TRD filter, is there any point to transferring the tube given the filters rigid construction compared to basic OE filter? I think the chance of it collapsing on itself is zero.
1939010
Not the spring, just the support tube. Spring not reused.
Ahhh
If the fumoto valve fails for some reason, can it be removed and the original plug be used as temporary fix?
yes I am curious also when the ordering will take place?
