Nah, flex seal your cruiserAt most, it's a two hour job to remove the sunroof, regrease the cables and reinstall it. A new glass seal is $40 or near that (I haven't looked in a while) and will last much longer than hope in a can.
Do you have pictures or tips on what to service and where to lube? What products do you use?I service the sunroofs on my LC and 4R once a year. Clean the channels and drains and grease the cables. Hate these sunroofs. My new Taco came without a sunroof... Peace of mind.
Two hours? You are just removing the glass right and then do your cleaning and lube. Sunroof is the most useless junk that manufacturers added to any vehicle IMO and expensive to repair or replace when it breaks.At most, it's a two hour job to remove the sunroof, regrease the cables and reinstall it. A new glass seal is $40 or near that (I haven't looked in a while) and will last much longer than hope in a can.
Nope.BTW, on my Isuzu there was a way to insert an Allen Tool and manually close the Sunroof ... is there a way to do that on our 100's?
Correct, there is NO manual close option on the 100.Nope?
So how do you close the Sunroof if the motor, gears, or cables break?
SOL?
Ya that's brutal that it stopped working after 21 years of neglect. These sunroofs on these Land Cruisers are useless junk. I don't understand how these things get their reputation for reliability. I had to replace my lower balljoints last year after only 200K miles. I mean, C'mon Toyota. Get your s*** together.Two hours? You are just removing the glass right and then do your cleaning and lube. Sunroof is the most useless junk that manufacturers added to any vehicle IMO and expensive to repair or replace when it breaks.
Yup. It’s a 20 year old sunroof that got beat in TX heat. I don’t use it ever.Nah, flex seal your cruiser
