- Thread starter
- #21
Yeah it was totally seized up.on the 80, which I assume is similar, it is trivial and very fast (minutes) to remove the actual glass, which helps a lot to check things out. However, dealing with the mechanism if it's locked up is a different story. You may or may not be able to move it by hand and then reattach the glass (best scenario if you're lucky). And god forbid if you have to get into the recess where the glass slides in cuz you'll likely need to remove the headliner which is a big job and fraught with expensive potential damage.
Obviously, if this all happens in rainy weather, it's not good.
