Well the mirrors do fit and MOST parts are interchangeable with your US spec mirrors. EXCEPT the triangular mounts that bolt to the door. They are the WRONG angle for LHD vehicles. I plan on having some made on a CNC machine that will work but this may take awhile.
The JDM switch with Retract button will control your US mirrors & vice versa. However, the JDM harness has one additional Blue wire on it (see top right of 2nd picture). I am assuming that this goes to a control unit or relay of some sort.
Note - If your US mirrors are not wobbling i.e. the tabs on the motor are in good shape. You can save a step or two and simply unplug the wiring at the tilt motor (note order) and drop it into the JDM housing and plug it into the JDM harness. One of my driver side US tilt motor tab was broken so I had to do a few more steps.
My donors were different color and I elected to use my US shells so that I only had to repaint the metal, triangular base. If your donor is the same color you just need to swap out the JDM mirror glass/motor with your US mirror glass/motor.
