J-Robs truck saga
We got the big chief on it now!
We put a ton of hours in on the rig this weekend. Not sure we took a single pic. Too busy working or drinking beer!
I guess I can update the status as I understand it: Links are done and tight, brake calipers and rotors are done, brake lines are run and almost done (had trouble bleeding the rear), ARB lines are run and hooked up, axle vent lines are run, battery box is fabbed and painted, knuckles are built and RCV's are installed in the front, Rear axle shafts will be here this week. Had to send several springs back to King to swap for a different spring rate. Radiator and fan shroud are almost ready to go back in for good. Front end body parts need to go back on and exhaust will need to be run after it's all done. Still a bunch of small stuff to do.
Hope to see this thing run by Labor Day weekend!
Spent a little time in the shop tonight.
Damn good thing I went over there. Those dip s***s can't figure nuthin out.....
Amazing work going on over there. Amazing.
Figured it's about time for an update
full hydro ram installed and plumbed
brake, axle vent, and arb lines routed from axle to the front upper link
knuckles built and connected to ram
winch and hoop reinstalled. power steering cooler right behind the bid. top of shock hoops with mounts for shock reservoirs
crossmember between shock hoops with reservoir mounts. that is a power steering line running across the crossmember. New 4 core radiator and fan shroud. Power steering reservoir.
we could not get the brakes bled at first (I have never had good brakes), we changed out the booster and presto! New master cylinder for the 80 axles.
plumbing at the steering orbital
rear shock reservoir mount and shock hoop and mount
new springs installed 200/250 in the front and 150/200 in the rear. sitting real close to ride height; however, they will need to adjusted more once the truck is fully back together. shock reservoirs are mounted
here are a few pics of the exhaust and front drive shaft
Tomorrow I'll be finishing up the rear exhaust and working on finishing up any loose ends. Hopefully Monday we will be able to fire her up!
If anyone is free tomorrow...come on down!
