astr, thats brilliant !! i knew it was real close to the 2F i pulled out.
If the factory tire size is 30" your gear is off by 3/10th's
REcalculate w/ 3:90 gears (act 3:91)
Huh? I am not exactly sure what you are talking about. I used an online gearing calculator and input the following:
Final drive - 4.11, trans ratio - .70 (gm 700r4 overdrive) and tire size of 33".
Am I missing something?
It's not complete, possibly it never will as there'll always be something to add or improve.
But functionally it's almost there. I just need to put in the front timing gear cover and water pump.
I've been busy doing nothing lately.Mid winter holiday.
it looks like you have a plate modeled up to connect to the isuzu engine? I am working on laying up the isuzu/a440f adapter plate, and make a mock up of this in wood or something.
any chance you can reveal that plate geometry for the isuzu? one hole patterns worth of guessing taken care of!
Bellhousing as requested.
Please note, these are my best measurements but haven't been verified by anyone else.
http://users.actrix.co.nz/dougal.ellen//4BD1T Bellhousing.PDF
Dougal, you've measured this stuff yourself from an actual motor no doubt. What I wanna know is, is there a site on the web somwhere that has this type of dimensioning for common motors. I also realise there are probably specialist sites that have specific info that that site is interested in, but what I'm after is 1 site that covers numerous common motors. Any ideas........![]()
thanks dougal, that is great. 425 mm PCD - this looks like the hole center to hole center dimension. whats PCD stand for? about 8 3/8 inches radius.
I will work on the landcruiser tranny bolt pattern, and will try and come up with similar measurements. thanks again!
I'm not sure that's a t-case, I think maybe it's tranny with a PTO output...
Isuzu PTO's usually bolt into the side of their gearboxes. The 6 bolt cover over the PTO port can be seen on most heavy duty gearboxes from the US, japan or wherever.
