Way I hear it, you have the good one. Oil on passenger side with the oil filter fixture integrated into the block. Oil filtration on f engines was bypass type. filtering oil as afterthought. The fs' (I think) had remote oil filter mount on drivers side. Someone here can tell you how to figure out exact man. date from engine serisl#s'. Transition motors are basically same as f except 3.54" bore. Your f should have 4 ring per piston with domes for 9 to 1 comp. Old fs' had 7.8 to 1 comp. More horseys. 2fs went 3 ring per piston somewhere in mid 70s I think. Look and see if you have header studs outside # 1 and outside # 6. I think old fs' lacked those 2 studs. Additional header studs a good thing.
