Is this bottle jack the right year for my 62 FST?
Oregon
Technically no; if it was from 1962 it would have a 5 digit part number stamped in it not the 10 digit on there. But that is splitting hairs, as I believe the general look is correct and very few would be able to spot the part number difference.
I believe the 10 digit numbering system started in 64?? John or Nerd would know for sure.
HTH :cheers:
I forgot about them switching to a 10 digit #sys...
sooo as far as his cruiser goes it would technically not be for his cruiser correct?
the jack would be for a 63-68/69 cruiser
John do you know when the switched to the phillips head screws? I remember something like it being 68 or 69
the ones i am 100% sure of haveing flat heads are a 63, 64, and this 67 I thought the thread Wesintl linked to had the 68/69 date but didnt see it there...i am also 100% sure they didnt have the flat head screws in 74 ...mine is phillips :)
Good information. This jack came out of a 67 and we are fairly sure it belonged there.
looks about right
do you have 62 with yours? Anyone have pics of a genuine 25 or early jack with the 5 dig part #?
Sadly no; none of the the three '62's I have had the original jack or associated bits with them. I only have a later philips head style mentioned above
63 was the first year Toyota used the ten digit numbering system. We got lucky in that Toyota published a FJ25 parts manual in both paper and micro-fiche in 1963 with the new and old part numbers.
:cheers:
Cool to know... interestingly enough the axles on the '64 FJ45LV we just picked up had 5 digit differentials on it.... I assume as Toyota did as they seem to have done with many parts and they just used them up until they ran out instead of making clean model year cutoffs.
hopefully punters attached is a pic of afore requested early toyota jacks.
you may have to ignore the jack snuck in from the dark side! jack on the left is apparently ealier; can double check the part numbers if anyone wishes. i did investigate this question a little in a thread called 'jacks and toolboxes' or similar. part numbers there. the earlier jack is perhaps a little cruder in the diamond pattern casting, minus the made in japan base plate script and also a slightly more elongated base plate with greater curviture at the outer edge.
