Is this a *new* heater core?? (10 Viewers)
Stuart, Virginia
I am midway through a heater box restoration on my 68FJ 40. After removing the heater box and extracting the OEM heater core, I found pin holes on the heater core cap near the inlet and outlet ports.
SOR advertised new FJ 40 heater core for $205 plus shipping, roughly $250 to my door. The unit came yesterday and I am disappointed. The supposedly new unit doesn’t look as good as the 57-year-old core that came out of the heater box.
The fins on the “new“ heat core don’t even extend all the way down to the bottom cap. The fins are rusty. The top and bottom caps, show, corrosion, scratches, and what looks like solder smears.
Worse, the inlet and outlet tubes on the top cap are not correctly positioned, they are out of square. This means that the new heater core does not fit square in the OEM heater box it is rotated and not flush at either end.
Did I even get a new unit?
The OEM tube outlet gasket pad from the original heater core fits perfectly squared to the body.
The same OEM gasket pad put on the new heater core is very crooked because the inlet and outlet tubes are incorrectly positioned. Which also means the heater core is rotated from square when placed inside the OEM heater box.
I will be talking to SOR on Monday trying to sort this mess out. This is the first time in over four years I have ever had an issue with any SOR product.
For those that have restored heater boxes and needed a new heater core, is it typical for a new core to look worse than a 50+-year-old one? Is it typical for a new heater core to have incorrectly installed inlet and outlet ports? Is it typical for a new heater core to not fit properly in the OEM heater box?
What I got just doesn’t look new. It doesn’t look like the picture on the website for sale. And it doesn’t fit properly in the heater box. Am I missing something?
Chip
VA Mountain FJ40
Rock Auto has heater cores listed for 1969 and newer. Specs below will let you know if it's interchangeable with your core.
$76.79 plus tax and shipping by fedex ground to 24171 is $18.99
Doesn't say refurbished, so an example of "new"?
Specs on this one from the rock auto website:
AGILITY 9010346 Specifications
ConstructionCrimp Tank
Core Depth (IN)2.000 in
Core Height (IN)6.250 in
Core MaterialCopper Brass
Core Width (IN)6.250 in
Inlet Pipe Diameter0.625 in
Outlet Pipe Diameter0.625 in
Tank MaterialBrass
OEM / Interchange Numbers: 87107-60091
I did not even think to try Rock Auto…
Dimensionally, the unit you listed is the same as the “new” unit I bought from SOR. The OEM heater core I removed is 1/2 inch thicker, but all of the replacement cores I have been able to find are the same dimensions as the rock Auto one.
A thinner heater core would work fine, as long as the inlet and outlet tubes are in the correct location, allowing the core to be installed square in the heater box.
VintageTeqParts also is selling new heater cores from Japan that actually look like new heater cores, and they are $50 less than the ones sold by SOR.
… So I have two alternatives if SOR cannot make things right… but first I owe SOR a chance to rectify the situation. But darn it, I had plans to put that heater box back together today… nope!
I think the red "rust" is actually raw copper. A little less fins is a little less effective at heat transfer, not like a big issue unless you are in antarctica. My extra large rear heater provides way more heat for the cab.
+1 for Rock Auto, prices rock bottom sadly sometimes quality is too.
Solder up the pin holes after cleaning with low temperature silver solder using the proper flux and put the old one back in.
It may be not-so-helpful now, but for radiator-related stuff, if you happen to have a radiator shop in town, they can clean & pressure-test things like this (or your full-size radiator) typically much cheaper than you can buy new. I spent a good few days dicking around with my heater core and no matter what home remedy I tried, I could not get all the scale out. I spent hours "flossing" the fins to get all the old hairs and lint out, but it still wasnt super clean. Local shop de-scaled, pressure-tested and cleaned it for $50, boy I wish I had started there.
Pro's with tools/experience are often worth their price. On the other hand learning to fix stuff yourself PRICELESS. Skills and knowledge are the lightest things to pack on your back - barring brain/body damage you will always have yourself; access to shops and the ability to pay not so much.
You are lucky to have an old school shop that still repairs versus just replace. Use to have plenty of shops that would would rebuild starters, alternators and generators. Can't find one any more. Knew of a radiator shop who use to rebuild them, they closed years ago. Can't help but think it's all the plastic tanks that helped end the old school radiator shops. Not just autos it getting to be most things that now automatically get replaced and not repaired.
Fair point, but I take a crawl/walk/run approach to skills development. Its too overwhelming to learn everything at once w/ a day job, marriage, kids, non-FJ-related stuff, so I outsource what I'm not equipped for now, and over time try to learn that stuff. But you are absolutely right, and the main purpose of this truck purchase has been to become more self-sufficient. That said, I am a big believer in local community, so if I can toss some coin around to an honest, local shop, I'm happy to do so.
Just got back from an old school radiator shop in King, NC. Dropped off the core.
However it seems my assessment of pinholes in the end cap was a bit optimistic. The end cap brass was corroded to paper thin in places. And there appears to be a crack at the base of the inlet tube. Their expert with such things will call me on Wednesday with a diagnosis of if it can be saved. I’m not optimistic. Given the newly uncovered brittle thin status, not sure if I could install hoses back on without flexing or breaking the repairs.
So the “repair the original” path might be a no-go. Time to consider other options.
I learned many years ago to be cautious about laying my money before the altar of Marvin Spector. Have you tried the local Toyota dealer?
I'm sure a good shop will help you select the best option for the money.
Finding parts, good service from vendors and shops for 50 year old equipment is what it is these days.
Thanks for documenting the journey - I'm sure others will be making the same trip at some point.
