- Joined
- Jul 26, 2008
- Threads
- 28
- Messages
- 354
Truck info: 1994 LC with ABS
So after some brake work (Caliper replacement with pads) I had spongy brakes. Wasted good amount of brake fluid trying to bleed them. I suspected that Air was trapped in ABS actuator but short of buying the SST tool or driving on Ice I did not see a way to trigger ABS.
While doing my front axle rebuild I installed my ABS sensor incorrectly which had resulted in ABS kicking in while descending steep grade. That had fixed sponge brakes immediately.
My question is how I can cycle actuator with out driving and with out SST tool?
Toyota lists 3 pieces for sst
Can somebody shed some light as how the tool works ? Voltages? Connectors ? So I can built my own.
I always trigger ABS on my other car after the brake work. But there is a "paperclip" override to do that. I can not find anything on how that can be done on LC. Any idea...?
Code:
(a) Connect the actuator checker (SST) to the actuator,
control relay and body side wire harness through the
sub-wire harness C (SST) and E (SST), as shown.
SST 09990-00150, 09990-00200, 09990-00210
