Just lately sometimes my brake pedal is soft. It travels further and I experience less stopping power. Tis only happens sometimes and is unrelated to driving conditions, i.e., it's not boiling fluid because it can happen the first time I apply the brakes in the morning.
If I release the pedal and then reapply foot pressure, it becomes firm and the truck stops normally. (Most of the time it works normally anyway.) The pedal does not sink while applying steady pressure, for instance at a stop light. There is no effect on the engine from braking at any time.
I have 4runner calipers and a rebuilt MC I replaced last summer. (I did have the rotors ground down to minimum thickness at that time.) The system was working fine until this week. There are no visible leaks at the wheels or elsewhere along the lines.
The parking brake is frozen at one wheel and only works a little bit. I have a diesel and I use engine compression in 1st gear for parking in most cases.
Haven't bled the lines yet but will... hoping for other ideas to try at the same time or subsequently.
Thanks for having a look.
