Any ideas/help is greatly appreciated.
2013 LC. I was converting the interior bulbs to LEDS. I had done the 3rd row dome light and front seat map lights a few weeks back, no issues. I was putting some different bulbs in the bottom of the doors as I wanted more light down there. I replaced the drivers side rear door light, no problem. Then moved to the drivers door. I put that light in and it went in and out. I jiggled it a bit and same thing, went on and off. I had to leave and I left the door open for probably 25 minutes. When I came back all the interior lights were out. I figured I could just close the door. open it and lights would come back on. No such luck. Left the door closed overnight, still no lights. Changed the bulb, no luck. Changed the bulb back to the standard bulb, no luck. So I manually tried the switches on the 3rd row dome, nothing. I tried the switch on the dash to control the brightness of the dash lights and turn on all the interior lights, no luck. Checked for fuses. Pulled the 7.5 amp under the hood, it was fine. Put a new 7.5 amp fuse in just in case, no luck. The glovebox light and the dash seem to be the only lights that work on the interior. Service Manager at Toyota scratched his head and started pushing buttons, like the SOS button. CLearly no help and they didn't have time to look at it.
Any suggestions?
thank you
Any suggestions?
thank you
