Do us all a favor and take a pic of the distributor where it meets the block.
Are you thinking he's already seized it?
Do YOURSELF a favor and take a pic of the distributor where it meets the block.
NOt seized, i have oil pressure every time, ok here is the stat, i've noticed that there are two different tdc, as everyone else has already mentioned. I got it to start, but a very hard start, and when it did, it would only run (barley at that) with the dizzy fully advanced.
What does that mean, 1 tooth off or 180 degrees.
Do you have the spark plug wires attached correctly? It's easy to reverse a couple of them, as I learned long ago.![]()
It's alive... It was just one tooth off, set the timing, adjusted the carb and put the aircleaner back on, good to go. I've just about done timing and carb adjustment so many times i can do it in a matter of minutes without a vaccum gauge.
I just have to say that it is amazing what cleaning out the inside of the dizzy did to the way the engine runs, i removed so much gunk, grease, oil, water, dirt, crap, and lots of rust out of that dizzy you wouldn't believe. I literally woke up at 9 am yesterday and worked on just cleaning out the dizzy for hours straight. Putting that bearing back in was a true bitch. But damn, it runs so good now, and vaccum advance finally works. Thanks for everyone's help, learned alot of valuable stuff.![]()
