Sadly, I have a 2wd as i want to make it into a minitruck. thank you for the information, if there is anything different for 2wd please let me know, thanks for the help.First post! Welcome to our slice of MUD.
I think we just had a discussion recently on the upgrade. You might try a search, or scroll down. As far as parts, the boneyards are going to be your friend. Do you have a u-pull in your town? Assuming you have the bolt holes in your cylinder head, the upgrade is pretty straight forward. Off the top of my head you will need (assuming 4x4):
Pump
Reservoir
Cooler
Gearbox
Associated hoses
The only hard part to find will be the ps gearbox. It was only used up to 1985. The rest of the parts can be harvested off trucks up to 1994.
Assuming you have a 4x4, converting to cross-over steering is an option, but more work. It requires 3" of lift, and welding to install. It uses the gearbox from ifs trucks which is more common.
...if there is anything different for 2wd please let me know, thanks for the help.
toyotaminis.com
