Well, I did not want to add any Jeep parts to the 40, but I have 2 anxious kids who want a ride!
I looked for any detailed threads on Mud and other sites, but mainly just found informative comments that "it could be done easily"and... it was pretty easy. I tried to keep the install as non-invasive as possible. 8 total holes drilled to mount the seat.
After searching for a while (and purchasing a wrong seat) I found the best true fit for the back of the 40 tub was model TJ Jeep rear seat (1997 - 2006). To my understanding, the TJ seats were the widest seats available, around 40'' at widest cushioned part. It fits the tub perfectly opposed to the first seat I bought which 1) had 2'' gap on each side at wheel wells and 2) could not fit two car seats.
I purchased the seat with mounting hardware for $300 on eBay. More expensive than I had hoped, and I'm sure if I was more patient I could have found one for 1/2 the cost on marketplace.
First step was to mock up the spacing on a piece of wood. I did not want to risk drilling any more holes in the tub than necessary!
Next I traced the measurements onto the tub. Used painters tape to keep the marks / drill holes cleaner
Make sure you get under the 40 to ensure you will not be drilling into crossmembers or the chassis! This next picture shows a light red line of where the chassis runs. In later pictures you will see how close the washers and nuts are to the chassis.
The stock jeep front hardware mount needs an outside spacer to keep the bracket stable. Luckily I had an old harbor freight bike mount that I was able to cut and paint match. This serves as my spacer. You can see in this next picture the bolt diameter fits perfectly in the 1/2'' ID pipe
After measuring out where the front seat mounts will go, next step was to get rid of the black and paint them metallic grey to match existing seat hardware. Im not too happy with the color match, I wish the spray was a bit darker. Either way, it looks better than black hardware.
