It SHOULD be cheap being a dead flat piece of glass but a lot of companies cant be bothered or charge you out the arse for having to cut it to shapeA 40 windshield is so cheap
I'd have to dig through receipts to be certain, but I had a glass shop replace mine for $200 I think
Not normally the type of parts I make
You stipulated happen to have a .dxf come for that shape you'd be willing to share would you?
Sure, for $450 and a contract stating you won't start manufacturing and selling FJ40 windshields![]()
Any competent glass shop can cut your supplied pattern.
It's usually one or the other DJ.I've never had good luck pulling out 40 windshields without them cracking, especially if you try to save the gasket.
This is plate or laminated safety glass Karl? Was in the glass business for many many years. Always hand cut safety laminated glass.That's where if you can have them cnc them out it's even cheaper and stupid repeatable.
I supply a dxf for glass in cabinets all the time when it's a complicated shape. I can set some nice tolerances and things just drop in the way you want them to.
We tried a flow jet on laminated glass when they first came on line. The pressure would seperate the lamination between the layers. Was really hoping it would cut curved windshields for chop jobs. I'm not aware of any way to do it other than with a good glass cutter, skill and a whole lot of luck.I guess I've never tried laminated. It's either been plate or tempered depending on where it's going.
Tempered doesn't cut. So they aren't doing that in house anyways.
I wonder if they can flip it and score both faces so it'll snap?We tried a flow jet on laminated glass when they first came on line. The pressure would seperate the lamination between the layers. Was really hoping it would cut curved windshields for chop jobs. I'm not aware of any way to do it other than with a good glass cutter, skill and a whole lot of luck.
Making the glass cut or run is easy. Lining them up perfect and cutting the laminate is an art. Not sure if a machine could replicate it.I wonder if they can flip it and score both faces so it'll snap?
I got a few quotes here in Boise for my '75.What are you all paying for a new windshield?
Only one glass shop up here would touch it and wanted $390, just for the glass.
