Install instructions for replacing FJ40 Rain gasket bought from CCOT
How about the instructions from CCOT:
"Weather-Strip (W/S) Installation Instructions.
  • Turn Hard Top (HT) upside down. Clean rain gutter free of debris. Lay W/S down on rain gutter w/beads to outside. Shark teeth cut to form HT corners. Position W/S bead just touching the inside of rain gutter rivets. Glue to seal W/S in place with 3M Glue Prt# 3M08011
  • How to Glue Weather-Strip: Unroll W/S flat. Apply glue in short sections. Eventually, you'll run a continuous bead of glue the full length of W/S with extra bead (2 beads) at each Shark toothed corner. Glue holds W/S in place and seal W/S when HT is installed.
  • When gluing W/S, glue and work short sections at a time. Apply THIN layer of glue on BOTH the W/S and rain gutter. Allow glue to air dry about 1 minute before bonding surfaces together."
