Ink Stain removal?
Discussion in '100-Series Cruisers' started by azvrod, Mar 4, 2007.
  1. azvrod
    azvrod
    17
    Aug 9, 2006
    Hi there, anybody have a miracle cure for removing ink stains from the plastic/vinyl dash? I accidentally made a small mark with a permanent marker on my dash, and Ill be damned if it doesnt appear to be permament :doh: ! Ive tried Goof-Off, several leather and vinyl cleaners and it just seemed to smear it and dull it, now it just looks like a grease stain, but its one of those things thats going to drive me crazy. Any suggestions?
    Kevin
  2. extremetoy1
    extremetoy1
    754
    Jul 7, 2006
    beleive it or not hair spray will remove it out of cloth...maybe try it?
  3. The Ox
    The Ox
    163
    Media:
    4
    Albums:
    1
    Aug 22, 2006
    did you try isopropyl alcohol?
  4. e9999
    e9999 You want to do what...? Moderator
    16,588
    486
    Sep 21, 2003
    US
    I know brake cleaner takes it off some plastic boxes I use, without damage. Do NOT try this on a dash without a trial first someplace hidden and then at your own risk anyway.... :)
  5. azvrod
    azvrod
    17
    Aug 9, 2006
    Tried the alcohol, didnt work. Ill try the hairspray and brake cleaner, Thanks!
  6. Jim_Chow
    Jim_Chow
    2,479
    6
    Apr 28, 2003
    Turquoise Trail, N NM
    Acetone will generally remove magic markers, but it might dissolve plastic, too. Again, test on an inconspicuous area.
  7. Albi
    Albi
    18
    Jul 12, 2006
    Palmetto Bay, Florida
    I've used this product successfully on a leather couch. I was able to remove a 4 inch ink mark. It takes patience as the ink lifter works slowly. Afterward I used the leather conditioner from the same company to re-condition the leather where the ink stain was. The ink lifter leaves a dull area after use. I was very happy with the results. However I am not sure if it will work on a dash.
    http://www.leatherworldtech.com/ProductInfo.aspx?productid=LMIK08
  8. donco
    donco
    149
    5
    Jan 16, 2006
    Albuquerque, NM
    I keep a jug of this at home & it works on almost anything, including permanent marker. The stuff is amazing & it's non-toxic & is safe to use on anything that's safe to wipe with water.
    http://www.bluegoldcleaners.com/cleaner.htm
    Last time I bought some it was $18 for a 1-gal jug and dilutes 1 part solution/8 parts water for general cleaning. For ink, I use it full strength with a damp washcloth. Their 1-800 should direct you to a local dealer.
