What would be on your (realistic) list for a 100 Series rear bumper if you were given a clean slate? Also, consider that every feature added incurs additional parts, materials, and labor that must be rolled into the price of the final offering. Finally, keep in mind that custom requests slow down the entire manufacturing process. The idea here is to come up with a bumper that most would agree on.
I will be taking suggestions from this thread and adding them to this post so that we can all get a good idea of what the collective has to say.
Here are some suggestions to get you started: (Material thickness, 100% bolt-on, rear cross member must be cut, hitch configurations, latch types, bearing types, dual swing-out, single centered swing-out, offset single swing-arm, light tabs, recovery point locations, swing-arm struts, safety mechanisms for full open/close, departure angles, aux light cutouts, jack mount, shovel mount, etc.).
Remember, this is for a 100 Series only.
1. As high clearance as possible without having to cut into frame
2. Recovery points located directly behind the frame rails
3. Capped wheel well ends
4. CB mount
5. Hi-Lift Mount
6. Embedded LED lights
7.
8.
9...
4. CB mount
5. Hi-Lift Mount
7.
8.
9...
maybe have to fire the Spectrum 625 up...
