You are correct. The wires that the fusible links connect to are Read White and Black.
Dome light, stop/brake lights and horn/hazard fuses are getting power when the key switch is Off.
With the key switch on ACC, those 3 circuits and the Cig lighter and Door have power at their fuses.
When the key switch is turned to Run, all of those circuits lose power at their fuses.
None of the other circuits in the fuse box have power with any key switch position.
I had taken the Aux power box out of the engine bay months ago.
I checked the plug's connections. I don't know which wire is which but one had constant power, a second on came on with the key switch on ACC. Both of those circuits show no voltage when the key switch is on Run.
I unplugged the key switch and tested wires. The black wire, which I think is the power from the battery, shows no voltage. The black with red stripe wire has 24.8 volts. The others have no voltage at all.
I went back to the fusible links. All show power getting through from battery.
